Oil Change 610
larry belli
I was reading about changing the oil on a sm610 and a spring and ball bearing were mentioned. I believe there are (2) bolts that need to be removed to drain the oil. Is this correct? An allen bolt and a regular bolt? The filters were cleaned my last oil change, so I'm not concerned with that, but I am concerned with the spring and bearing. Anything I should be aware of?
Thx
The only spring is on the oil filter on my 09. Nothing to do with the allen or hex bolt for drainage though.
