Oil filter change - leak
rockdancer
Changed the oil filter on my 250 and when riding it there is a small leak from where the oil filter is
Do you normally need to replace the rubber gasket or o ring ?
Do the bolts just need to be super tight ?
There is a strange bent washer /spacer part which I think goes between the filter and the engine - is that right .? manual is not much help
thanks
thanks
mate the rubber o ring lasts about 3 to 4 oil changes its $ 7.00
dont over tight the bolts or thay will strip
bent washer is norm it puts pressure on the filter and keeps it against the housing
Don't over-tighten the bolts ... Something will snap .. ... Some of that liquid gasket stuff works there also to seal off the seeping ...
