oil level in1982 cr 250
Take your oil fill cap off, look in the case, see the little shelf on the inside of the outer case, fill to there,when bikes level. It's about 1.25 quarts. You could start a big rowl , when asking about pre mix ratios :doh: LOL
Husky John
Normal Oil ie Not Synthetic, 32:1, a fully synthetic racing 2/ oil such as motorex can be run at 50:1 and up to 80:1 if your brave. cheers
The size (RPM and load range) of the engine, and if its air or water cooled, have far more to do with how much oil it will require than the type of oil used will.
