oil question: 10W-50 in TXC250
JPinNC
Don't you all just love oil questions?! Anyway, I have been using 10-60 only thus far in my '09 TXC250. I know many of you use Rotella 15-40 in your four strokes, so I can't imagine that 10-50 would be a problem, however, it does get pretty hot here in the summer, not unusual to ride in 85-95 degree weather. I'd like to try the 10-50 to see if I get a little smoother shifting.
Since Husky recommends 10W-60 do you think there is any harm in running a lower viscosity oil in the hot summer months? I definitely plan to run 10-50 or lower in the winter.
Been using Spectro 20-50 semi in my 250 since 1st oil change. Not as hot here. I was extremely impressed with the amount of oil coating the top end (valve train) when I removed the valve cover. Nice and sticky.
Spectro is good stuff, best shifting quality I have found yet, but closest shop that carries the stuff is about 1 1/2 hours away. Local shop carries Belray which I can get in 10-50.
Oil thread alert!
I prefer Wesson- smells great when used in hi-perf engines. Especially after I've made donuts with it!
