Oversize piston?
tonskiguy
Has anyone actually replaced a stock piston with an oversize in the 511or 449? If so, did you have to replate the cylinder bore? What piston to cylinder clearance did you shoot for? I know what the manual says, but that seems very tight.
Normal cylinder to piston clearance is 0.06...0.08mm (in diameter). Piston rings gap is 0.4mm.
Most modern bikes use a plated cylinder. You would have to bore it out (if there is enough material to do so) then re-plate it to size. Other option is to steel sleeve the cylinder (LA Sleeve) to whatever size you want (within limits). Sleeves don't need plating and you can bore them out multiple times. I am not a Husky expert but this is the standard practice on other bikes.
I appreciate the comments, but what I'm really after is, did anyone ever do it? I've read the manual, and I am aware of the printed specs. .06mm is like .002", that seams very tight to me. I'd like to know that that is not a misprint. If someone has measured and installed a piston with a bore clearance of .06 - .08 mm in a TE449 or 511, and had success, without siezing, I'd like to hear about it.
I have a local machine shop tht will plate the bore to whatever size i want, so, I just want to be sure. Thanks!
If the cylinder in dimension tolerances (A, B), have a hone, without scratches, then do it and enjoy riding. :)
