JeffCollinsart
I recently painted my TE511 wheels black. They turned out well so I thought I would pass on the process.
1. Clean and degrease wheels
2. Take off wheels and scuff with red scotch bright pad
3. Wipe down with mineral spirits
4.deflate tires and loosen nuts on rim lock and valve steam
5. Tape around base of spokes. Then tape up the spokes You only need to mask to where the spokes cross.
6.then tuck note cards between rim and tire to mask off tire
7.I put a pipe in the vise and put the tire on it to spin while I painted
PAINT AND PRIME
Use an etching primer, I used an automotive primer that was black. The paint I used was VHT wheel paint satin.
Now just follow the directions on primer and paint
PAINT AND PRIME
