Parts required plse.
husqyhamm
Hi All
I require the crankshaft primary gear for 87 500XC. Has 37 teeth and partno 1616 029 01. Will likely be stamped 029 on gear.
Also required kickstarter gears. 83-86, and 87 later will also be welcome.
All help appreciated.
hh
Thanx And, would really appreciate one of those 029 crank gears, would enable me to use the clutch now just hanging on the parts rack.
Th G/S, oi ve everybody wants it to convert to HPN. As for me its just the best dirt road cruiser in Africa. Use it once a year for a good trip and all smiles.
Why 37? if you want that part number it seems to me to end up with 39 by the parts sheet vs tech data sheet. The 39/70 is very common on early 430 and all xc 500 and some cr 500. Some (maybe most or all) of the cr 500 with less than six speeds have less teeth.
Added later,
It seems that part # is specific to that year. All mine have 885 on them and are 39 like I show in this clip from the tech data. The later ones are lightened up between the taper and the teeth.
Thanx Fran...k
In 87 Husky made the 500 XC with the particular 37t crank gear, which goes with matching big 6 bolt clutch and one piece 73t clutch basket stamped 028 and matching allu clutch cover. All of this i have with new plates etc.The 87 400XC may have had it too but i have no info to verify.
I only require the primary to use the whole setup on a LC build.
To be specific, this is the setup. Photo taken from the 86 50XC thread on restorations.
