Parts swap 86 to 87??
turtle5353
Hi guys can anyone tell me if you can swap the gas tank and radiator louvers off of a 87 and put them on the 86?? I like the looks of the 87 alot better than the 86. Or is there more differences than just the tank and louvers??? Any help would be great thanks Kevin
You have to add the tank mounts I did it on my 86 430ae, and yes they are a lot better design.
Check out my thread in vintage restoration forum hhtp://www.cafehusky.com/threads/1986-430-auto-resto.21749/ I stolle a set of mounts off another frame.
Thanks for the reply. that is a beautiful bike you have there. So the seat and airbox and everything else is the same i just need to get tank, tank mounts and rad louvers and i have a 87 style bike?? Theres an 86 husky 250 near my place with a spare motor. I was wanting to look at it but wanted to make sure i could convert it to an 87 first. Thanks a ton!!!
The tank / seat is a little wider on a 87 so you will need a different seat as well. If you get I have a spare seat with good foam, just needs recovered.
Sometimes when buying these things it isn't worth arguing about what year the thing is with the guy seling it. Engine aside there are quite a few differences in the chasis I will try and phrase these as how the 87-88 differs from the 85-86. 250,430,500 two stroke not talking 125 or four stroke
the forks are either the upsidedown ones of the cr or a more complex internal design
the rear hub has about a pound shaved off it and uses shorter sprocket bolts
The frame as discussed above has the gasoline tank attached by one small bolt going down in the front instead of a long one going through
All the following plastic parts are different air box number plates radiator scoops
The swingarm and linkage is different, there are quite a few differencs in how the tubes go in the area of the footpegs in my collection but the place the linkage attaches in different left right and maybe up down and front back for the newer 87-88 linkage. Different top shock mount left right as well.
The radiators themselves do seem the same, four stroke radiator longer with smaller cap.
Just because folks list stuff on ebay as all the mono shock water cooled stuff is interchangable doesn't make it so.
Fran
Yes,
Frank is right, there are alot of differences in the frame, suspension, motor, and forks.
Only some parts will interchange.
Well thanks for all the info and replies. If i just wanted to get the look of the 87 on the 86 would the tank seat radiator shrouds do it for the most part? everything else on the bike i dont mine but i really like the look of the 87 tank andshrouds...... or should i keep looking till i find the 87 i have been wanting??
It really depends on the condition mostly if you plan on riding it. These generally are bought by folks who enter events ride them hard and often and sell them a couple of years later and then eventually become someone's beater bike. With the 88 there were a lot of extra ones and the price was cut so the chances of finding one that didn't go through the life cycle described above is greater. I don't know enough folks for a large sample but moving to a ktm 300 in 1992 or 1993 seemed pretty common and some folks just kept the husky as they had many prior. Eventually they decide for some reason to liquidate all dirt bikes which is another way to avoid the normal life cycle.
As to your question the inner airbox, air box cover and both number plates will be in order to fit up against the seat and tank. What do you want wr, xc, cr.
Fran
