PCV Auto Tune
gillies
Does the PCV Auto Tune adjust for altitude and how quickly will it do this? I frequently ride at locations between 1,000 and 7,000+ feet - Phoenix desert to Flagstaff mtns. Will the Auto Tune recognize the altitude change and immediately adjust air/fuel accordingly? Does it work in a similar manner to my car or GSA?
As far as I know, the PCV doesn't have a separate MAP sensor in it.
There is a spare 5v input you could hook up to it & make a map, but as I don't have any first-hand experience with them, I'm not the guy to ask there.
There is a MAP sensor on the TE449/511s, but it isn't used for engine load measurements. (The engine will run fine with it pulled from the throttle-body as a test, still wired in - no 'Fail' messages)
As far as I can tell, it would likely be there only to measure current atmospheric pressure at switch-on PRIOR to winding the engine over on start-up.
As I see it, if you climb to the point where it runs poorly, if you shut it off, wait for the system to shut-down & restart, it would take on the new atmo reading.
Just my theory, for what it is worth.
Yes it adjusts the air fuel ratio, the map sensor does not matter, it works off of the O2 sensor supplied from power
commander. It works pretty slow, but would definitely help. Most on here that ride those type elevations and say
the stock bike does well. If you all ready have PCV, its an easy matter to have 2 maps set for different applications,
Yes it would. It changes it basically immediately. It only needs a few miliseconds to 'see' the air/fuel mixture at a certain RPM/throttle position and make adjustments.
2200' to 7000' here, PCV/AT, FTMFW!
I got two maps set up. One for fuel mileage and another for power. Works great.
Just found this in the workshop manual.
As I thought, the MAP is only for atmospheric measurement & therefore could only take a measurement when the engine is stopped as it is ported into the throttle-body. (Note line #3)
