Please Help...Clutch Issue 2009 TE310
ncgrecon
I've found some information on here about my issue, but nothing is working.
Clutch Lever Went Dead. No Pressure. master Cylinder seems find, put in rebuild kit 8000A0914 about 400 miles ago. Nothing leaking at the slave. Blew out clutch line with my air compressor and back filled the fluid with a syringe from the bleeder by the slave. Had pressure for a bit then started the bike and put in gear, then nothing. Now I cant even back bleed...won't let me push the mineral oil back through the system.
Please all chime in with your suggestions.
weird. I suppose if you can't back-bleed, maybe you need more freeplay at the lever- to allow the master piston to retract past the relief port.
That is, assuming you don't have some other blockage (thinking chunks of o-rings here).
good luck.
