power commander V
huskyrick;123483 said:
has anyone try power commander V & dynojet auto tune ?? is it worth spending $600.00 to put 2009 te-310???
For that particular bike, 'probably'. If you had a 2008 it would be far more important.
It would run cleaner and smoother more than simple adjustments by using the iBeat parameters. You would also be able to adjust the afr for max mpg or for max power.
But the question that only you can answer is, is are those things important to you for that amount of $. Some people spend much more than that on exhaust systems & other things as a matter of course. Other people keep the bikes as stock as possible to keep expenses down.
If you get one, get an Auto Tune as well, this will give you increased power and a smooth trouble free ride, I use one on my TXC 250 2010
That is for sure! The Autotune is awesome. I would never get a PC without an autotune.
It fills in the parameters for decel conditions (higher rpms, small throttle openings) that the maps provided from Dynojet do not contain. They focus on the acceleration aspect.
sharpie1;123729 said:
Trying very hard to keep my mouth shut.
You don't need to. I only have experience based on... 5? bikes over a year ago.
Did you ever get your situation sorted out?
No, I just gave up on the autotune, when it worked it ran way too lean and way too hot, now it just doesn't work at all. I feel it was a total waste of money. I sent it in once and they sent it back and said nothing was wrong with it, sure enough it worked for about 400 miles and just quit again, I dont want to spend any more money to ship it back again so Dynojet can tell me it's fine. My bike runs great and cooler without it so I just don't see the point in dealing with it any further.
That is too bad. Sounds like you got an intermittently working unit.
Not good.
My experience was completely different, but I did not really get any long term reports back either. For the record, I still have the 2006 with a carb, I was testing on other bikes, but my pcv & autotune was on someone elses bike for a few months. Not sure how many miles.
Those things have been used on sooooo many bikes I really don't think they would be in business if it was an ongoing issue. But I really don't know.
:thumbsup:
Thanks for you input
