Premature Camshaft wear....
sharmas71
I have had a starting issue with my 2010 TE 250. When you press the start button you would think the battery was flat(fully charged and new)
One revolution only.
Replaced the starter motor and still the same.
Took the engine to a local bike dealer whe asked me to call in to see what they discovered.
The camshafts have movement in the journals. You can rock them!
Any thoughts??
Sounds like your bearings/journals are toast. I'd drain the oil and check for metal bits. Doesn't sound good...sorry.
I dont see how movement in the journals would cause your condition. Might not be good but not your problem. Sounds like your auto-decomp is not working. Hard to say anything without seeing the bike though,
Moving cams will cause the valves not too open and bike won't start.
You could re-shim it tight but it would not last long.
I'd call Mike at engine dynamics.com, he can fix bad journals.
