Problems from faulty Battery
yoshiboldor
Hi, I have read a few threads where people say the bikes will not run unless a good condition battery in installed.
Can you please explain what the symptoms are (other then starting problems)?
Cheers
The only problem I've had with a low/older battery is poor starting, and MAYBE poor running at lower RPMs, when the charging gets real low from the stator. I've had ALOT more problems from faulty wiring than from bad batteries.
Batteries can always be tricky but maybe have it load tested at a local auto parts store. Just fine out out what the stock cold cranking amps should be as the guy at store most likely won't know for motorcycles and depending on the unit they use might need it. Often the voltage will read 12 volts even when they are bad.
Cheers
When my lithium battery took a crap on my 2012 TE310, the bike ran like hot garbage, misfiring, sputtering with no power to speak of. Had me scratching my head but ended up being the battery shorted from vibration of the running engine. Not sure this helps explain what you're experiencing though...?
