OlderHuskyRider
I am assuming several things about this subject, please correct any incorrect assumptions I have made:
I assume that the "T" in the pic below is what people are replacing, because the majority of fluid (60%) may be going to the left-side radiator throught the Straight portion of the "T", leaving the other 40% to go to the right-side radiator. The "Y" is supposed to make it 50/50.
If 60% of the fluid is going to the left radiator with the "T" stock, wouldn't the crossover/equalization tube shunt the overage to the right-side radiator?
I am assuming that no one really cares how much fluid is going to either side if the temp is below boiling.
If my fluid is hot-to-boiling, wouldn't I want most of the fluid going to the right-side radiator, with the fan, for more heat exchange?
Why don't I just reverse the "T" that is stock, and make the straight part of it go to the right-side radiator, then 60% will go to where the fan is.
