schimmelaw
I have been plating misc components on my project rebuild and have a question for those of you in the know. Here goes. If I pull the kickstarter knuckle off the shaft on the outside of the case - does the kickstart lever then loose all the preload on the spring insde the case? It seems like I remember that you pull the left hand side case off the bike w/out removing the kickstarter hence you don't mess with the preload/tension on the interior spring. If I were to remove the exterior kickstart knuckle for plating can/would someone explain the reassembly procedure?
I need to know that I can replace the kickstart lever wih the correct tension after plating before I start ripping stuff apart. Thanks in advance.
Rick
Rick
