R&D Power Bowl
loony888
who's got one?
how do you find it?
easy to fit?
are they worth it?
my bike is set up well, except for a hot stall i get once in a while, though, since i opened up the clearances on the valve shims it's almost gone too. I'd love to hear the thoughts of those of you who have one or have used one.
cheers,
paul.
I have one...to be honest, I am not sure if it matters. I got it the same time I went with the JD jetting and have it adjusted to JD leak jet specs...it is nice for sure, but I haven't adjusted mine since installation. Looks nice, but I would say.....save your money. You would probably do the same as me and never adjust it.
That's really all the fancy expensive carb parts are for. Just to make fine tuning easier. If you don't ride at different elevations much, you may not change em after the initial setup. But for those who race or leisurely ride all around, it makes small adjustments that much easier to make
