Race gas Anyone run it?
Jimmy250
I have a 2010 TE 250 I have started using 50/50 split between pump and vp4.4 in my sons little TTR 90 for racing and it makes it run better. Anyone do anything like for a fuel injected 4-stroke?
Tried a bunch of race fuels.
Best performance for the $ is VP racing VPR fuel.
Starts better, performs, less flame outs and decel pops.
Plus doesn't gum stuff up like pump gas after month.
I gone up in octane but runs crappier.
VP110 is what I use and what works the best. I've remapped my son's yz450 with a map that takes advantage of the better fuel and got big gains in performance. I use AV100LL in a pinch which works almost as good and costs 1/2 as much. I also use VP110 or AV100LL in every 2 stroke I own including chainsaws and lawn equipment.
Unless you're running really high compression, or tons of timing (which probably won't help anyway), it's hard to beat pump 93, or even better, E85.
Try running more timing and fuel at low and mid-range (more snap and less flame out + more mid power) and retard the timing on top while leaning out the fuel. In this top end situation pump gas will detonate but with race fuel it will burn evenly and it literally feels like you hit the nitrous button.
Ethanol free for sure if you're carbed. I've run leaded ethanol free race gas (110-114) in a 4-1 mix) for my bikes.
I used to use VP, but if you get it in the can expect to shell out 13-18 dollars/gallon and you're buying a one time use can. I found Sunoco 110 and 115 leaded at a local ultra hipo race boat place for $10-11 gallon. I'm 50/50 Race and 100llAv in my 2 stroke racer and 1 gallon AV:4 gallon high octane pump gas plus Stabil to kill ethanol and octane booster to prevent detonation on my hot map on the 4 stroke.
My last trip to the airport got me AV for 3.85/gal which is only about 25 cents/gal more than our average super unleaded. And that's here in Commifornia!
Maybe it's a California thing because I can get VP110 for $7.50 per gal in CO and $8.25 in MO from a guy who seems to prefer not selling it. AV100LL is $3.98 in MO
