Ran the bike low on oil. How much damage do you think ?
Russ Henry
I have a 2013 TXC 310. Last weekend I was riding it very hard for about 30 plus miles. I started with a fresh and full crank case. At the end of the ride I notice oil film all over the bike and could not see oil in the sight glass. I discovered that the line on the right side of the motor that runs from the top down to the filter had come loose on top. When I filled the oil up to see how much I lost. It looks like I only had about 1/4 of capacity of oil left. The bike ran great all day and did not make any goofy noises and it starts and sounds fine. Any thing to be worried about ?
Thank you for the input
Change the oil and filter. If you don't see any metal you're probably alright.
I ran mine without oil before and its still running.
^^^^ as above shouldnt cause an issue if you still had oil in the crank, you need to find out if the rings are blowing out the oil from the cases somethings not right.
