We use 80W oil ..what's everyone else use on here?Is this rattle noise coming from worn down gears?
In the video I am in neutral with the rattle noise, in first without the noise, and in neutral again with the noise.
Is your clutch lifter starving for oil? I have been told to use 80w gear oil in the crankcase.Although I am ignorant, that's my educated guess too. I think I will first give the clutch a little more movement because the arm barely swings
