RE: TC 449 2013
PawPaw
Where can I obtain a flywheel puller, a replacement shifter and sprocket bolts for my bike?
I have not located them on any listed site here or by doing an online search.
Thank you,
Paw Paw
Paw Paw, give me a bit & I'll get back to you on the puller. I'll check on some files I have. I'm pretty sure it's the samples a KLX110 Kawasaki. (I'll make sure)
Sprocket bolts are fairly universal, any bike shop could help you there. Measure the length and diameter.
These aftermarket shifters are heaps better than stock. This seller ships worldwide.
Thank1/4"s for the info on the shifter, but I don't see and company name or way to order.
The issue I find on the sprocket bolts that all I find are too short, by about 1/8-1/4". I have ordered a couple of set market to fit the TC449, but were all short. The TC bolts are at least 1/4" longer than those of a Honda Crf450R. I have looked at Motion Pro, Hub Saver, Primary Drive and several others and none are long enough. They need to be at least 1 1/8" long from the end of the taper to the tip of the threads. I have even tried to locate some OEM units, but can be found.
Info on the puller would be great.
Thank you,
Paw Paw
Sorry Paw Paw, I was on my phone when I replied & couldn't share the e-bay link for the shifter correctly.
It is here -
http://www.ebay.com.au/itm/ALLOY-GE...68?pt=LH_DefaultDomain_15&hash=item3f49231b50
This shifter has much better splines than the original one.
The puller is here -
http://www.ebay.com.au/itm/FLY-WHEE...-2008-2009-TE510-2008-2009-2011-/301572494496
The bolts I used on my last change came out of a universal bolt kit I got from the local Honda/Ktm dealer.
Length on them was pretty good (TE449 not TC), I'm not sure if the TC hub is thicker?? Maybe as a last resort Hall's for genuine....
Thanks David for the info on the flywheel puller that we need to use for the Kymco engines. I've been trying to find what one it was for awhile now too.
