Rear brake pad Too hotinsulators and shim
gergte310
please comment on what should be done once the insulator is cactus -if you run without I assume the rear brake will over heat faster- I punish the the rear brake in the single lane stuff causing an over heat issue and rear brake fade until it cools down?
Te310
