Rear disc loose?
millenium7
I noticed a rattling sound coming from the rear of the bike, quite a lot of it actually. I inspected the bike and found the rear disc itself is loose. I can grab it and wiggle it quite a bit, there's an alarming amount of play in it. However i'm not sure 1) how it could happen and 2) what the fix is? It's secured by what I describe as metal grommet's which the disc floats on. The grommets themselves are tightly affixed to the hub, but there appears to be no way to have the rear disc grab the grommets better?
On my last Husky the brake rattle was pretty bad - lot of miles. Someone suggested that I take the metal grommets (to use your phrase) off and rotate them to mate the unworn side with the rotor. I never bothered. I put lots of hard miles on it and it just rattled away happily. This adds "character" to the motorcycle. Instead of a floating disc, you can tell your riding buddies you have a super-free-floating disc; it's advanced technology that they wouldn't understand...
BTW - I kept the dirt wheels off that bike when I sold it and I will use them as-is on my current bike without reservation.
I think the official fix is to buy new "metal grommets" because that's the part that wears, causing looseness and rattle. Nice no-cost idea in the above-referenced link too. I might even try that if I get bored one day.
Silicone sounds like a better idea. I trimmed part of a zip tie and wedged it in one of the pucks, this would cause the disc to be ever so slightly offset but for the moment its stopped rattling. I checked for clearance issues and all is good so i'll probably leave it like that if it holds up. The rattle gave it a 'what the hell is wrong with you' character. Not really something i'm looking for...
