Rear Wheel Bearings
huskyista
I have an 09 TE 250 with bad rear wheel bearings. Question; Is replacing the wheel bearings difficult? I looked in the manual and it showed their removal using a drift punch. I don't know if the bearings have enough difference in diameter for a drift punch to get a good bite on the bearings to knock them out. Has anyone had experience replacing these bearings? Are there any special tools made for the job?
Thanks
Many folks use a punch to remove old bearings without issue.
But anytime I try to do something "the easy way" it usually gets messed up.
A blind bearing puller and proper drivers are a good investment.
Learn to do it right and it will pay off for you in the long run.
Your bearings will last longer and you can always make a few bucks off your schmuck friends down the road.
Easy....remove the seals and circlip under the seal on one side of the hub if there is one.
Sprocket side of the wheel has two bearings the brake side has one.
Push inner sleeve to the side and tap out old bearing on the side with one bearing with a drift pin...maybe heat the hub a bit to make it easier. Tap even on each side so bearing comes out straight. Don't cock the bearing. Flip wheel and tap out two bearings on the other side.
Keep track of how it all goes back.
Put new bearings in the freezer, heat the hub with a propane torch.
Get the proper size socket from tool chest. Socket should only hit the OUTER RACE...if you tap the inner race you will destroy the new bearing. Tap in the new bearings...make sure they line up straight and they should all but fall into place.
Replace circlip and seals and you are done.
Thank you, I'll give it a try when I get some time:thumbsup:.
I got the bearings out today. Your advice worked. I would like the Tusk bearing puller if I did it again https://www.rockymountainatvmc./p/2801/20342/Tusk-Bearing-Remover The spacer sponge was full of water. I used wd 40 to help get the water out. I'll let it dry. To keep it from absorbing water, I'll spray it good with spray grease before assembly:thumbsup:
When you put the new bearings in put as much waterproof grease into them as you can. I put mine in the freezer for 2 hours so they slide in.
