Rekluse settings for a TE250
racemx904
Just looking for what everyone is using...
I only have about a month on this bike and it seems like the clutch is set at the lowest RPM setting....it needs to be set higher I think to help it rev out easier...
not sure but let me know what you are running...Spring and balls...
Thanks
which version do you have? the EXP, the z-Start Pro or the trail version?
I have the z-Start version on my TE 250 (with the Athena kit). I like a medium engagement RPM with the softer engagement rate. This is a good set up for me in the tight, technical riding we have here in Washington.. but also keeps the clutch slippage to a minimum for the the summer months when we ride steep terrain, where a high engagement RPM could cause overheating issues with the clutch.
It all depends though. Terrain and riding style make a huge difference - this is my third Rekluse, which I've had on three different bikes. All were set up slightly differently, but for the most part, the bike makes less difference then where you ride and how you ride.
i have the z start...
it is set like yours...
makes it tough for getting over logs and such without the clutch...it just wont lift the front wheel up and over...
feels like it kicks in way to early..
I do race HS's and starting some enduros...most is really tight stuff...
yeah, you may want to go with the softer engagement spring then?? although with the 300 it's not a problem at all getting the front wheel up in first or even second gear at low rpm's, but then my gearing is pretty low (13/52 currently) and the 300 is a different animal from the 250.. maybe try lowering your gearing as well?
