Removing The 250 Crankcase Web
jimspac
I bought a crankcase set from a 1984 250CR to convert to use for the 430WR I am rebuilding. What is the preferred method to remve the 250 crankwell web to use the larger crank of the 430? Do people typically break them out or machine them out?
Of course machining would be the perfered method.I guess you could get out with a course burr and a air grinder.
Hello, I have a set of 1984 250 WR Cases that should be the same thing. The Bike sat to long and has Gut Rot in the 250 Web area but the rest of the Case looks good. As I have a Bridgeport Mill I could Machine mine out as the Cases are junk anyway for a 250. If I like the end result I would be glad to do the same for You.
I know it is easy, I just do not have the equipment I used to have. I did not want to sell everything as I wanted to stay in business after selling some equipment to pay for a retrofit for my NC mill that was ailing. I sold my Monarch engine lathe and had a kid coming in to look at one of my two Bridgeport mills. He saw the NC and wanted that instead. That put me out of business. Then I only wanted to sell one Bridgeport and that guy wanted both. My wife said sell him both. I wanted one for projects. She said you will always be in a shop, just use one there. Doesn't work like that most places around here these days
If your cases have the separation web, I would think so. But I recall there being a difference between 1981 and 1982 250 cases but the 1981 430 cases are the same as the 1982. I hope someone with better knowlege chips in here
