jayvlnt
Hey Guys,
Went for a ride today and noticed a slight ticking noise coming from the engine. When i got home i decided to to start it up and give it a good listen and was certain it was the cam chain.
i had never played with a cam chain tensioner on a husky, and assumed it was similar to that of a yamaha, with the screw clockwise release mechanism. When i removed the bolt to my surprise this wasn't the case. So i did a little google search and realised it was a spring held in by the bolt.
And here is the problem
There was no spring, nothing!!!
i have come to the conclusion that the previous owner of the bike must have been smoking crack and just forgot to put the spring in or something odd.
Now i believe that because there is no spring it has not automatically tensioned
So my question is, is it just as simple as removing the two side bolts on the tensioner and pull it out seeing how many clicks out it is, then if needed getting the chain replaced, and replacing it with a new CCT (one that contains a spring)
Thanks J
Thanks J
