Resettable odometer recommendations?
Pete Ross
I have a 2009 TE310. I'm looking for an odometer that can be adjusted up or down in 10ths of miles so I can use a roll chart and adjust to match the mileage to match the sheet if I miss a turn. Does anyone have a recommendation?
I've been using a watchdog enduro/ rally computer for years. It's almost bullet proof.
It has dual sport and rally mode that you can adjust on the fly.
Build with an aluminum case
Drawbacks is its not back lit so hot need a light source if you are going to use at night.
Not the cheapest or most well known.. But it's deffinately a top notch product
http://www.dugasengineering.com/dewebsite2013_002.htm
Didn't see in the specs that the odometer is adjustable up and down in 10ths of a mile. Does it have that capability? Thanks for the lead.
This may sound dumb but I use a Sigma BC800 bicycle computer. Cost me $15. It has survived 3 bikes so far. Has a 1/10ths resettable odo I recall. Cam.
