Kawagumby
Hi folks,
I've now got about 5 hours on my TE250 with the suspension settings pretty much finally dialed in for my riding area - a mix of hard pack, decomposed granite with lots of ruts, stutter bumps and a lot of advanced trail-wear.
When I first started riding this bike, the suspension felt pretty rough, the back end was riding high, and wouldn't track the terrain. The front was not responding well either, with the hydraulics being out-of-sync for a balanced front-to-rear action. I have pretty much tuned the clickers to what works for me, but the bike still wouldn't do what I wanted in some turns, and it was more work than usual on tight, technical trails, as a lot of concentration was needed to keep it in line.
My intial rider sag setting was 100mm, per the book, which is close to what I have set all my Japanese bikes to, over the years (100-105mm).
I could tell that the bike was "stink-bugging" too much with that setting so I went to 110mm. The bike handled much better, and would hold a line better too - but, it still wasn't right. So I went to 115mm sag.
Even better...hmmmm...why? The spring rates seemed right on...I'm a 165 pound guy and off of jumps there was no bottoming, and the suspension travel I'm getting seems pretty good too. The valving and spring action is firm yet compliant with no spikes. My forks are set up in the triples at the second line (about 1/4 inch) which is how it was setup when I got the bike.
I read about KTM pds (no linkage) bikes and most of the suspension tuners recommend 115 to 120mm of sag for off-road bikes of that design. I began to wonder if the frame design of the 2014 TE, formerly a Husaberg pds design, might have some "residual" pds design issues that could affect the new linkage setup differently from the Japanese bikes.
So, I set a full 120mm rider sag and went riding today. Much better.
With previous settings I could not hold a line in a sweeping berm, as I'd have to continually deal with some oversteer. As noted previously, the bike required unusual concentration to ride in technical settings. Now both those issues have vanished...
Now, you might be thinking, this guy ruined the steering! Nope, it still turns very well, and there has not been a hint of push (or wash-out) even when ridden agressively on dry, slippery trails.
The static sag is 40mm a full 10mm over spec. This is the one thing I do notice (rarely) when riding on faster downhills when the rear is unloaded and hitting obstacles. In those situations, you can feel the intial rear travel being kind of "dead" when compared to less static sag settings. In all honesty, I don't have an issue with that and don't know if that equates to any kind of negative action at all.
For what it's worth..that's my experience.
