WHITEROCKET5.9
ok so i have a arc and a mme shorty clutch lever and there is something with both of them that doesnt quite work with the magura on my 09 txc 450....the mme lever is too thick to fit and the arc has a 5/16 hingepin hole where as the stock clutch hinge bolt is a 10-24..or close to that. sooo i went and got a few things at farm and home and i plan on riggin er up. im either goin to just bore the top and bottom to the same size as the hing hole in the arc lever and slap a 5/16 bolt with a lock washer on it through there and be done with it orrrrr i have a hardend roll pin that i might cut and stick inside the arc lever so that itll act like a spacer for the stock bolt ...what do yall think
