Right side main bearing size - 1983 CR250
I order alot of parts from there. In this case my timing does not allow for it so the size of the bearing is needed as I am in a town that has a very reputable being shop that I have used before.
3205C3.
Make sure you get the "maximum capacity" version with 14 balls per side. Many places sell a 9 ball version... Don't do it!
Please check out SKF 3205 E C3 I have been using ZKLs as replacement - now I may switch based on oldbikedude post .
I called SKF and talking with engineer found that the E designated bearing is new engineering , new metal, new heat treat. I ordering one and will have one soon.
Not verified but it may have one less ball bearing per side, but still maximum rated.
I was happy with ZKL but unsure as the quality repeating itself during manufacture, being from a former iron curtain country. Cost was about 20 bucks
Cost on SKF about 82 and was quoted more. Also going to use their 6205 C3 for the left crank bearings for now on. Their explorer bearing has been
upgraded in roller design and metal used also a few years ago.
The tranny bearings don't have as much RPM so most good quality Japanese bearing can be used.
Still looking for higher quality needle bearings for the critical kick and idle gear. SKF may not make their caged needle bearing.
He said the INA bearing may make the beat needle product. not verified.
Please note SKF owns MRC - they make the 3205s .
Humm - guy said SKF being a Swedish company is obsessed with metal quality
SKF is definitely one of the very best. Expensive, but you get a quality product. This time, I'm using the ZKL. I was ready for a few new bearings, myself, so I called their U.S. distributor recently, as this bearing has been a hot topic here on CH lately. I was told that ZKL, too, has a very recently upgraded 3205C3. I just bought 3 of them for various projects. Of course, you can't tell how good a bearing is by looking at it, but it does have 14+14 balls, the loading slot, and very nice finish work. They will be L + R mains in my '73 400 and R main in my 82 500. Neither of these motors are finished yet, so no bearing failures yet! The ZKL's are so far working great on the workbench!
Oh - about a year ago I bought a full set of main and trans bearings from one of our "usually reputable suppliers" here on CH. Oddly, the right main arrived as a 9-ball version. I didn't recognize this at the time and, in fairness to the supplier, I never notified them. It would not be fair to say they knew about this and cheaped out on us. It could have been a surprise that slipped by them, too. I'm only mentioning this so we can all be aware... ask what they're sending you! I did not, and will not, use that bearing in any of my motors.
