Running in a new engine
suprize
What processes are out here? anyone got a tried and true method they can share? any dont's to be aware of??
cheers
i have always used a heat cycle or two, then ride it around varying the rpm, trying to avoid too much load....
Yeap me too, i let it run for about a few minutes, high idle, let it cool completely (one heat cycle). Then either do it again, or ride it real slow & no load,
for a few minutes ,then let it cool completely again. After that you should be good to go.
Husky John
I was told by my old husky dealer mix the oil a little heavier start it let it idle rev it every 4or5 mins repeat for 30 min put a fan on it to help keep it cool then go out and ride it easy till the 1st tank is gone then ride it like dick burleson!
tom
Just ride it normally. If the rings get too hot, they will expand the piston into the cylinder walls. So don't run it hard until the rings have had a chance to seat.
its depends on if its a total rebuild, or just a topend. i only ride it easy and vary rpm for a half hour or so if its a topend...bottom end maybe a whole tank....probably overkill but thats ok..
