sem cdi coil replaced with vespa unit
ty w
ive just built a cdi to work sem stator with my cdi to any ignitor coil, if you want one let me know, my next step is to build a double cdi in one block, so if it fails theres a backup, just swich the wires
Hi ty w,
Could you post some photos of the set up you have and maybe a schematic of the wiring you are using on your Husky.
Cheers 2T_vs_4T.
my previous cdi swap of this that and the other brands havent worked that well, but now i just made one to work with any ignitor coil, and it works great . if you want one let me know
sem stator resistance is 220hm trigger and 1750 ohm ac ign powr
If you had access to a scanner you could draw it all out on a standard letter size sheet of paper, scan and save as a jpg then upload it within a message. Within the last 2 days I found I actually have 2 SEM ignitions and 1 I know actually works
