Setup for tall rider
Respring and possibly revalve the suspension for your weight>I'm at 225 without gear and I like mine the way it is.I can get away with damping adjustments with the stock valving.I would also say a taller seat is in order,there are several good companies in the "common topics"/Aftermarket vendor section.You may also want to open up the seating/handlebar position with bar spacers,or a steering dampner to raise the bars and stabilize the ride,again there are some top notch dealers associated with this site.The shifter tip can also be extended and I believe that there is a Yamaha brake tip from Zipty racing since I'm sure your boots are 13+ and will feel somewhat awkward with the stock foot controls.Speaking of foot controls the footpegs,there are some really good options to the stock when you trash the stock ones.Read some of the set-up tips for that bike this site has a wealth of information about your bike.And last but not least when you get it set your gonna love it. Enjoy:thumbsup:
First make sure your handlebar mounts are rotated to the forward position (look close and you will see that lower bolt is not centered so rotating 180 degrees moves them back or forward). Another trick is to flip the footpeg spacer over (this requires cutting it off) or getting pets that have reversible spacers...
From there, bar mount spacers and taller seat would be the next step.
