Shift Linkage
dkwkid
On m75 CR360 I had a problem with the shift linkage inside the side cover. My son took the bike around the block and had to push it back. The shift lever was flopping around and not moving the linkage. When i took in apart the linkage appears to be a press fit on the shift shaft. It was not pressed enough! I had both ends tack welded to keep the linkage from slipping on the shift shaft. I don't know why it was just pressed on-maybe to give in case of a spill.Iwelded mine.
