86 WR 250
After a trip to some proper riding grounds, I unloaded the husky from the truck and went to go ride. The problem is that I notice that If I up shift the lever stay up, if I down shift the lever stays down. so while riding you have to gently push it down then shift again with out accidentally shifting the opposite direction. What's odd is that if it's in neutral and not running I can feel the spring returning it to center with my hand if I move it up and down. I don't have a spare clutch cover gasket or patience to take off the clutch cover again. (everytime I do so the kick start assembly falls out and I have to rewind the spring which for me is about a 2 hour process with lots of swearing and skin lossage) Last time I did it was to replace all the bearings and seals on the clutch cover and related parts.
I'm asking for suggestions or at least thoughts on what could be the issue. Also, is the shifter stuff located between the right case and clutch cover? I can't tell from the manual I use. Also, I don't even know what parts are related... http://www.halls-cycles.com/images/PDF/Husqvarna .PDFs/1980-1989/86_all-2st_models-2.pdf
Just asking for some guidance or suggestions.
Thanks.
Thanks.
