Slipped Liner
RTM
My 88 WR 250 seized on me today, second lap into an event. Having just pulled the barrel of I found that the liner had slipped down a few mm allowing the ring to pop over the top, resulting in the top ring being ripped off.
Only thing I can think of is she got to hot but the radiators were still full to the brim.
Any idea's?
Took the head off (didn't want to as head gasket are not available) and the top hot of the liner has sheared off allowing the liner to drop..
What to do.
If there is no damage to the head you may get away with having the cylinder resleeved and get a new piston and ring set. You should figure on flushing your crankwell to remove any fragments that may have ended up down there. I personally would split the cases and check the crank for damage as well. I wonder if your liner had been work hardened perhaps and became brittle.
Yes a strip down and flush is a must do although it all looks just fine down there. The bike has down very low hours since new and is still on it original piston and probably rings (maybe chain and sprockets even) no evidence of the piston nipping up and pulling the liner down the bore. bit of a mystery. Bl@@dy shame as it was going and sounding fantastic.
Check on eBay for tritrophy Search for husqvarna gaskets and you will find his store. He had them when I got my centercase and base gaskets last month
Found it - Thanks. Just need a new piston and liner now. Think I'll make a liner.
The sleeve may have developed a stress crack in the corner where the flange intersects with the outside sleeve wall. Then the aluminum cylinder got hot enough to expand and allow the sleeve to pull down from the flange
I wondered the same, however a few years ago I warmed a cylinder in the oven in order to paint it pot black and the liner fell out when I took it out of the oven so the aluminium clearly expands a greater amout than the liner and actually lets go rather than pulls it.
But the bike did get a little warm a couple of miles earlier before it let go so something happened that's for sure. No water loss though - ziltch !
They always go great just before they let go:eek:
