tls25rs
In the process of multiple projects with my 06 SM510R and had a few questions hopefully someone here can help with.
First - Can someone out there with a stock SM510R, that hasn't been taken apart at all, take a picture of how the electrical cables that run down the main frame back bone go from above the carb back to the battery/ECU area and post it? My bike has been apart more than a couple of times and I would like to get the routing back to the right way this time.
Second - To completely refresh a motor on one of these bikes from splitting the cases up what would be the proper parts list? I'm thinking what is listed below but want to know if I missed anything or have something extra in there.
All bearings in the cases
Connecting rod/big end bearing
Piston/Rings
Timing chain
Gasket Kit
What else?
Thanks
Joel
Piston/Rings
Timing chain
Gasket Kit
What else?
Thanks
Joel
