Smog cannister removal
firerider
My 2014 TE 449 has a smog cannister as required here in Calif. Besides making the bike a little lighter, is there a performance value in removing it. I have a four year extended warranty that I would like to keep and just wondering if removing the canister would void it out. What is required to remove the cannister: plugs/block off kit????
Pretty sure it would void your warranty, but I can't say for sure. As for removal, there isn't much to it. Take it off, vac plug the hole on the engine, pull out the hose that runs down under the skid plate, and reroute the gas overflow down the back right side of the bike. You can run down by the rear shock and zip tie it to to frame. Just make sure it's not near the header pipe. It's long enough to reach passed the linkage. Some gas may spill out of it when tanks are full.
I have the te 310 , full power removed all the smog crap and have had a couple warranty things done since with no problem , might depend on the dealer also.
