Smr Suspension?
MotoGreg
I just got a 2010 SMR510 and I need stiffer springs. I haven't raced SM in a few years but I believe in my last bike I ran .58 or .60 fork springs and a 6.4 shock spring.
Does anyone know the spring rates that come stock in the SMR510? I can't find it anywhere, I've searched online, looked completely through the manual, and even emailed Marzzochi USA.
Did it have some type of marking on the shock spring identifying the rate so that I can check mine as well? Or did you have it checked? Any idea on the front? The rear doesn't seem bad but the front is way too undersprung.
it has a tag on the rear spring, dont know about the front springs
I finally found the spring rates on the Husky parts microfiche. It looks like the SMR has .50 fork and 6.4 shock (vs .45 fork and 5.6 shock for the dirt versions). So it looks like I may be good with the stock rear spring and just need to set the sag... now I just need to find some fork springs. Thank you for your help TROFFER88.
