Solid rear disc for 2010 TE450..
If you ride in sand etc the solid mount disc is ok. if you ride in mud the floating disc help prevent build up of sludge on the brake pads which hastens their wear
Hmm, hadn't thought of this idea. That rattle surely is annoying, especially during the miles I didn't know where the noise was coming from.
Remove each bolt for the rotor and use silicone on the cup washers. Made the disc quiet and still is able to move some. I did that to my 08' years ago and is still working fine.
The wheels were from my 09 te250 and 14txc310r. Took the rotor of my 14 which is a fixed rotor and put on my 09 wheel which had the floating rotor. Also have a set of wheels from an 06 tc 450 i think and they swap over to that as well
