08 510 smr. Got past the breakin period changed the oil and checked the valves. Exhaust was perfect and the intake is at the low end of spec. Any tighter and it will have to be adjusted. Anyways, I've noticed that the bike is a little messy. Has a little oil coming out of here and there. Doesn't actually drip just a little mess. Is this pretty much to be expected? I've also noticed that since my first real ride (150 miles and fast) after the breakin the engine does feel a bit looser and the bike starts a lot easier but it makes more engine noise. A little clickety clack. Is this normal as the engine loosens up? It's not noisy by any means just some subtle mechanical noises that weren't there to begin with. I know that there is no way to know for sure if the noise is normal since you can't hear it yourself, but in your experience did the bike make more noise once broken in? Thirdly, while on this ride there were a couple times when cruising at a steady rpm the engine would sort of hesitate. Kind of like slightly letting off the throttle. Never did it while accelerating though. It wasn't a big hesitation, it was very subtle. It this just a FI quirk or possibly something else?
