Spark plug socket for 2010 TXC 250?
ioneater
Man, feeling a little silly asking this but..... What size socket do I need to remove my sparkplug? I'm switching over to an IMS and wanted to check valves and spark plug gap while the tank's off. None of my deep well metric sockets seem to fit:banghead:. I've tried 13 thru 16mm and either the socket won't go all the way down or it appears to go down but doesn't engage the plug. Special tool for the plug?
I had to turn down a standard small plug socket to fit into the hole. All the ones I had were to fat to fit.
FYI, it's a 16mm or 5/8" size. The gasket that seals the spark plug well to the head protrudes a slight bit into the spark plug well and may require a small amount of pressure to make the oem style sockets go down past that gasket line. I ended up using my son's crf50 plug socket with no issues after confirming the size needed for the spark plug. My plug was gapped at .023 inches. The manual calls for .027-.031 inches.
