Speedo on but no digits displayed
millenium7
Noticed this the other day, i suspect water may have gotten into the unit when washing it. Is it possible to disassemble it and make sure everythings clean and dry?
Alternatively is there anything else that could be a problem and worth checking?
You can remove a couple of the covers, then after doing that hit it gently with a hair dryer and see if that helps. I'd only do that if I were certain that it has water in it though. That said, my 610 has the same dash unit, and I've never gotten water into it (that I'm aware of) even using a pressure washer from time to time.
So before you take things apart, you might try disconnecting the positive battery cable, count to ten, then reconnect and see if that fixes things. It's a 'known thing" with that dash.
