Speedo on, but not working
Arctra
Hi guys
A couple of rides ago I had a stick lodge inself in behind the front number plate/ligh assembly and rip one of the plugs apart. It instantly killed the bike, so I presume the plug pulled apart has something to do with the engine kill switch. Anyway, I had to re-join the plug before I could get the bike going again. It was only near the end of the ride I realised the mileage hadn't incremented at all which I thought was strange.
A couple of rides since then and I have noticed the speedo does not work at all. It powers up with the key being turned on, but when moving there is no speed readout, and the mile-meter does not increment.
Does anyone have any suggestions as to what I need to do to fix it? Do you think the cable/plug that got ripped apart has anything to do with it, or is there another cable I need to be looking at?
i've had this on my 610 twice. disconnected then reconnected battery and it sorted it. dunno if this is the same as yours due to the damage you mention but worth a pop
yes I know your problem . You have lost the pickup magnet on the disk for your hall sensor.
Easy to check just takw a look at your front disk.
Either that or you lost that connection to the pickup magnet as well, which seems likely since the stick came up in there and knocked something loose already.
