Speedometer trouble. 2011 TE449
TNcoontail
I hit a rock and damaged my speedometer wire at the bottom of the fork leg. I spread the wires and put some liquid electrical tape in, let it dry then taped it up. It worked okay for about 100 miles then quit again. I bought a new wire for it today and nothing changed. The spedo lights up but stays at zero. The magnet is still in place and the only thing different is that I threaded the new one in flush where the old wire was actually rubbing the magnet. Any suggestions?
check the sensor with an volt meter set on AC voltage. when you rotate the front wheel you should get voltage. you can also check it with the ohm setting on the meter as a static test. I don't know what the readings should be but if the ohm reading is over limit or out of range you may have a defective sensor. If you don't have proper voltage you may have a sensor gap issue.
