spoke size
samp615
I am relacing a 1979 cr250. I lost 3 nipples. I have a 1976 ke125. Can I use nipples off the kawasaki?
If not, here can I purchase individual nipples and what size
Ruining about four nipples with the spoke wrench and vice grips both is about normal for me. I suspect the front ones are thinner than the rear ones. I would try Halls http://www.halls-cycles.com/ at least you can get the parts sheet. If it is the same number as for 83 to 88 rear I have enough used ones to not miss three. Entire wheels worth of spokes and nipples have come up on ebay with just the part # but I never was intrested. 15 years ago spokes cost $4 and nipples $2.
Measure the diameter of the spoke in mm and then how many threads per mm those are kind of crucial to be right.
