sprocket removal kicking my butt!
Matt Cummings
Hey guys. I can't get this darn sprocket off my 72 WR 250 Its one of the older tapered fit jobs. I have tried about everything. Used a plate and two bolts and a ton of heat and nothing. Anybody got a tool that will work? Any ideas?
Also I'm looking to replace the shaft out to a splined drive with the c clip. Anybody know where I can find the exact dimensions so I can see if it will fit.
Doubt if that puller will work.
Find the correct puller when you do use a hose clamp around the legs and get it tight.
Heat only the sprocket not the shaft.
Had one so tight let it set overnight with a lot of pressure on it next mourning found the puller and sprocket stuck in the wall.
Have had some that only way was to use small cutoff wheel must be carefull not to nick shaft.
Some can be tougher than others, especially if they have spun and welded themselves together.
Later george
Up tite- I was heating just the sprocket but it was transferring into my home made puller. I tightened it down so much it also flew off like you said but I caught it burning my hand lightly. Better than a wall or window.
Auto- wow that's awesome! Let me know if you got one.
