stalling 450te 2010 when selecting first gear
husski79holland
When i select first gear my bike will stall, what can it be?
It starts good. I must drive away whith a lot of gas. And than it runs fine.(sorry for my english)
Try to select 2nd gear and see what happens.
Also, check the gear position sensor also known as the idle trasponder assy, the wire might be burned or parted or unplugged, or there may be a piece of junk in the sensor that is blocking the metal contact on first gear, that's why it would be helpful to know if the bike stays running in second gear. In the pic below, the smallest brass dot is Neutral
Thanks for the replay, i will go check the gear position sensor. And i need ti use the clutsh more to drive of. In 2nd gear no brobleme (i think)
Does it stall immediately when you select the gear? If so does it feel like the clutch is engaged? If so that might indicate a clutch/lever related problem.
Otherwise the side stand or gear position sensor ideas above would be worth looking at.
Uw Engels is beter dan mijn Nederlands !
I need to drive off with a lot off clutch!
And sometimes its fine.
Maybe i found the probleme, ter was a small red wire from the ignition coil to the steer( behind the head light) and was damagde. The first owner had jused it as a supermoto and i think he had a gear indicator on the handlebare. There was also a black wire leading there from the gear position sensor. I will give it a try this weekend.
Do you mean "drive off with a lot of throttle"? Sounds like a clutch issue. If adjustment is not working take a look at the clutch basket - sometimes it gets notched and does not allow the plates to separate properly (keeping them engaged). I had that problem on my KDX and I just pulled the basket and filed down the notches...the problem went away but I will eventually need a new basket.
Seems the clutch might be engaging too late. Try adjusting the clutch pressure springs and do a clutch master and slave purge
Good fun, I am sure, except they let you trample all the tulips :-)
I probably would have crashed half a dozen times
There was a usles red wire from the ignition coil trough the handelbare, this was wornt out. Every time i steer complete to the right it got caught up.
