Starter gears 2010 te 250
Jimmy250
Hi anyone replace these? I am told this is why I keep killing battery's! And eventually will burn out my starter! Any help is always appreciated!! Thx Jim
I just did this repair. I've learned that this is a very common fix for these bikes. Take a look at need2boat previous posts, he gathered good info from others on the forum and provided step by step how to with pics.
R_Little, can you explain putting the flywheel on just right? To me it looks like the flywheel can only go on one way as it locks over the woodruff key.
Remove all burrs on the woodruff key then lightly lap the flywheel/crank end interface with a little valve lapping compound and tighten with the proper holder and torque wrench to 75nm.
DON't just blast it on with an air gun.
Not done right and the flywheel will spin on the crank causing all kinds of problems.
Does anyone have the flywheel retaining tool, I am trying to locate one to rent, borrow or buy? Thx!
Well I replaced the starter gears today and the old ones where a bit worn but, it did not fix the problem. I am thinking of replacing the starter its the only thing left. Any thoughts?
