STARTER MOTOR 250 TXC HELP
emanuel bastos
Good I have a husqvarna 250 txc 2010.
I've always had a problem and nobody got it resolved, the bike to cool the starter works fine, but hot the starter is not strong, it seems stuck, has led new battery, new rectifier current, the starter has been open and there is nothing strange.
what is it? gear which may be the starter work?
Does it kick start easily when it won't electric start?
If it is also difficult to kick start, I would check your exhaust cam to make sure that you have the updated one. On the left side of the exhaust cam there is a spring. It should have a little bend in it. If it is straight instead of bent, that will cause it to be difficult to kick (and estart) because the auto decompressor isn't operating properly.
If it is easy to kick start when it won't electric start, then your starter is probably fried and will have to be replaced.
I have an early model 2010 TXC 250 and went through the same thing as you. I had to replace my exhaust cam and the starter motor. I also bought a new ring gear and worm gear shaft, though I never installed them.
THANK YOU, I'll check the trees and the cam automatic decompressor.
where can i find the workshop manual models TE, TXC, CT of small engine?
